I have a 16hp tecumsch engine on a 70s scrambler,and its real slow.I'm sure my riding mower will out run it and its over 12 years old with the same hp.The engine seems to run ok,has good pulling power,and rev's up fine with belt off .With engine off I checked to see if acc. was opening all the way when I pressed gas pedal and it was.The choke is open to.The engine don't rev up when pulling so I'm sure nothing is slipping.It just don't wind on up when moving.My acc. linkage is hooked to a lever on bottom of engine block,from that lever a spring and rod hook to carb. I don't know if that lever on bottom of engine is acting like some kind of governer. Any help would be appreciated
