Question..... what is a Transaxle Automatic Transmission?Yet alone where can I find one or can I make one? I found and old artical that had one in a 6x6. Here is their discription.....
"Two sticks start, shift and reverse the six wheels. To go, you push both levers forward. Pull back on them and you reverse. Push one and pull the other to change direction in the length of the machine as one set of wheels goes forward and the opposite set go backwards. Let go of both handles and you come to a stop automatically.
Transaxle Automatic Transmission or TAT as it's called, works this magic with an infinite number of gear ratios from High to Low. The TATs coneshaped drive discs hold the secret that makes it a clutch, variable speed transmission, and differential all in one. You don't have to build or assemble the TAT, you buy it and install it as a unit.
Throttle control is only used when starting up the 8-hp, 4-stroke engine. The TAT takes care of all speed and direction change requirements."
Now.... anybody have any ideas??I tried to copy a picture but my pc is throwing a fit.
