Hello again. I was examining all the chains on my 1996 Max II and noticed that the right side (passenger side) chain assembly - the vertical one is very loose. It appears as if you could remove a whole link to tighten it. I have no idea how it got like that as I bought the machine used and also had someone install a new engine last spring. The other parallel chains running the sprockets appear to have the correct tension. How can this be corrected - replacing the chain - adjusting the jackshaft ? If I make an adjustment to tighten this chain, what effect will it have on the other chains? Looking for advice. Thank you.![]()
