Cold air intake
I have modified the air intake on my OX so now am getting the air to the engine from outside the engine compartment. This has really improved the performance of the machine. The mod was easy enough ( I am not the most mechanically inclined person you will meet) Took a 6 in to 4 in reducer for a heater vent mounted it on the air filter housing, after cutting out most of the end of the housing. Then took an adjustable 90 degree 4 in elbow removed one section and attached it to the reducer, Removed the back of the seat so I could mark where the air intake would contact the engine cowling. Then took a 4 in hole saw, cut where the intake met the cowling. Used metal tape to seal all attach points and the other end of the air intake. I used a 4 in heater vent from a rv for the cover on the intake. Rich with Alaska Mudd Ox had measured the air temp at the intake after 20 min run time at 140 degree F. He figured we were losing about 35 -40 percent of the power from the engine. I will post pictures in the gallery under Mudd Ox cold air intake.
Tinman
Smile, it's only gonna get worse.
