I heard you could put 25x12x9 tires and 9 inch rims on my hustler to replace factory 8inch set up.could someone let me know what I can upgrade too,and where to get them from.I have a 5 lug pattern if that helps any.Thanks
6x6World member jerseybigfoot has 25x12x9 Goodyear Rawhide IIIs on his Hustler 950. The 25's are an excellent upgrade for that machine. You can get a brand new pair of 25x11.5x9 Goodyear Rawhide III tires (which will be just a hair taller) shipped to your door on ebay for $100, which is a great deal.
GoodYear 25x11.5-9 Rawhide III Honda 3 Wheeler 2 Tires : eBay Motors (item 260602055318 end time Nov-08-10 07:27:45 PST)
Sweet found them on ebay,but how about the 9inch rims I need?tire problem solved.rims I need rims lol.
I was talking to Jersey about this a while back and I don't believe the 25X11.5X9 will work. they are a good bit taller than the 12" version and would rub on the 950. you might be able to remold the lower tub, but i seem to remember that it was a clerance issue between the center and rear tire
The 25X11.5X9 may rub the top front of the front wheel wells. The distance between the tires in rear is not a problem. A wheel spacer would probably help or a little heat to remold.
Soo if I go with 25x12x9 ill be ok on clearance?
I believe that forum member Boncrushr fitted 25"x13"x9" to his 950 without too much work.
