Help with clutch adjustment and identification on Coot
Results 1 to 10 of 18
Thread: Help with clutch adjustment and identification on Coot
    May 2014
    VT
    520
    Unhappy Help with clutch adjustment and identification on Coot
    So I recently replaced the very worn out belt on my Coot, the original was starting to delaminate and was WAY too long (could easily pinch the middle together, in fact it could be removed buy just slipping it out of the pulleys!) Since the previous owner had installed a new engine he simply ignored the much too long belt and all the slip it had when driving, not acceptable. So I precisely measured for a new belt and installed it. The belt now fits perfect with about ½” of deflection and turns easy on the engine clutch when off. However the engagement speed on the drive clutch is MUCH too low, it is impossible to change gears and even letting the engine run down to a couple hundred RPM into a stall is not enough to disengage it.
    My first machine the Scrambler had the same problem, it however had a comet clutch which I easily could pull apart and put spring tensioners in the form of sectioned pipe against the main spring to get the engagement RPM right. However on the Coot the clutch is SO close to the tub it can NOT be removed while the engine is still in place. Worse the engine is squeezed against the front brake so if I want to pull the clutch out I will have to pull the engine up and out as well )-:
    Before I do all that work if anyone knows what make and model this clutch is and how it is adjusted that would be great. My old Comet when you undid the bolt the end would spring off. This one when I undo the bolt just slides back and forth on the engine shaft as one unit.
    Fairbanks AK
    1,456
    The clutch appears to be a 780 series comet. I can see it's completely disengaged now. I find that loosening the belt slightly to lower the drag on the inside of the belt can help. A belt will usually squeal on the inside hub of drive clutch when driven is held or transmission is in gear. This clutch is calibrated by changing the roller weights and springs.
    Sep 2012
    Hanover,PA
    1,012
    Your side sheaves look like thy could use a Polishing for sure. That would help it not pull on an idle .
    May 2014
    VT
    520
    Googling 780 series comet it does look like that model, it does squeal a lot, especially when I turn the engine over while in gear (as there is NO way to change out of neutral once the motor is running) In fact the starter will actually turn the tires the clutch engages so fast! There is sadly no way to adjust belt tension. The engine and transmission only have one place they can be bolted to the floor, the old belt was 52" and as I mentioned unbelievably lose. I made a mock up belt that fit perfectly at 42", the closest belt size I could fine that matched was 42.2" so it really was pretty much perfect. In the 1 3/16" belt thickness I'd have to drop to a 39" or go up to a 56" the is no other in betweens and I looked everywhere.
    Wedge don't tell me that, it took 2 hours to get them nice and rough with some 320 grit sand paper! Lol, I really don't think the roughness is the problem, It could be contributing but I think the springs must just be set too soft. I'm really hoping it can be modded like my older Comet, anyone have pictures of one of these dissembled?
    http://i130.photobucket.com/albums/p...pslgqcdtu8.jpg
    Yikes this looks complicated how is one supposed to adjust this? Buy new springs? Where would I even start?
    I now recall my old one was a Comet Duster. That thing was super simple, though I doubt it could even fit in the small space in the coot.
    Thanks,
    Fairbanks AK
    1,456
    If the movable face moves in at idle the clutch is wrong. If it truss to crawl when cranking the belt is to tight. I see several belts listed in the 42.5-44" Carlisle spec sheets. The max series belts are measures to the top width and do not taper to the edge. I run belts run them from widths listed as 1-5/32-1 7/32 top width. Also put a tacometer on engine and slowly raise speed until you see the movable face of the clutch jump in. Usually 1200-1700 rpm is in the ballpark. Then call Don Jackson 608-774-0481
    He can tell you what weights and springs make up any engagement speed you want. He is at Certified Parts Corp. the company that now produces comet products. Hope this helps.http://www.hiperf.com/acatalog/beltdimensions.pdf
    Check out Max3 dimensions, I see the top widths have gone away from 32 of inch from my old chart.
    May 2014
    VT
    520
    Angry Why is this so complicated?
    Ok my buddy and I are stumped after wrestling the clutch out and taking everything we could off of it (bolts, retaining c-clamp) all it does is rattle we can NOT find a way to open the unit. What are we missing? If we pull up on the outer curved case all it does is hit the flange of where the C-clamp was.
    For such a popular unit it also bewilders me that we can not find any videos or "how to" in dissembling it.
    Sep 2012
    Hanover,PA
    1,012
    Spray some PB Blaster on the center of the Bell where it is center shaft then Gently pry it around the lower edges to pop it off.
    Looks like it is just rusted on there ?
    The only thing holding the bell on is the snap ring and the 3 bolts so it should just pop off !
    Feb 2016
    Mississippi
    1,108
    Allwheel, look carefully around the center shaft and see if has any swollen spots as a result of someone driving it onto the engine with a hammer. A swollen spot will keep the outer cover from coming off. If you will take a file and dress the outer edge of that center shaft it may help you a bit, if it is in fact swollen in places.
    Sep 2012
    Hanover,PA
    1,012
    Good point ! I forgot about that
    May 2014
    VT
    520
    THANK YOU! I wouldn't have thought that could have been a possible problem but it was what had to be done. We removed a scary amount of material before it finally slipped off. The weird thing is the metal was mushroomed out exactly as you described but from the inside edge not outside almost as if extreme force was pushing the bell housing up. Well the cover is off and now I have more questions. I see the 6 horizontal springs set in their 3 groups against the rollers they are very rusty I see no way to identify what color they once where. The thing I'm confused about is whether or not there is a "main vertical spring" Such as this: 300397C DRIVEN SPRING RED 780 DRIVEN - COMET
    I don't see any big center spring like on the duster just the 6 small outer springs, is there no main spring as I linked above hidden somewhere? And if so how do I access / find it? Do I have to remove all 6 smaller springs first?
    Thanks for all the help guys!
Tags for this Thread
