I got all my parts for my bad bearings and started with the right rear bearing. I went by the service manual step by step but somethings wrong I started with putting the outer flange on the one with the grease fittings then the bearing I locked the bearing down with the set screw lined up my fitting with the hole in the bearing then put the gasket on then the inner flange. Now here's the problem the manual shows the out flange and the inner flange right on top of each other but I have a 1/2 inch gap with the gasket between them. I checked to make sure I have the right parts for this one I bought a new outer flange a bearing and 2 gaskets. I'm reusing the inner flange because there was no damage to it. I no the outer flange is the same because it has the same numbers on it as the old broken one . The bearing does not go far into the outer flange and I don't want to try to press it because cast breaks easy it's not sitting on the seals that are in the outer flange there's a small gap between them. To me it looks like the inner flange should sit over the bearing more. The bearings O.D is 2.44 inches and the inner flange I.D is 2.01 inches. The bearing sits in the outer flange a little more then a 1/2 in. I've been trying to figure this out for a while now and I'm ready to through something.
