Well, with the the dash design beginning to be formalized, I'm going to have to run wiring soon. So, time to start building the "power section":
New deep cycle AGM marine battery, bought for this purpose. The tray is just the floor with "stops" welded on either side. The hold down is just a steel strap bolted through the floor. The floor section is bolted down to the Argo frame. The "tray" will get a layer of rubber for a bit of abrasion and vibration damping, although an AGM is vibration resistant by design.
The power wire to the front is a 2/0 gauge welding wire, with the end lugs crimped and soldered. It currently goes to the starter solenoid, which will double as a lug point for the winch power. Ground will be the Argo frame and I'll just put a short 2/0 gauge jumper from the batt neg post to the frame, then a ground jumper to the solenoid and ground jumpers where needed to make the power path. The Pos cable currently is directly to the batt Pos post, but I'll get a "mega fuse" to put between the battery and feed wire. Prob a 60A fuse. Enough to take the entire load of what I have planned, but small enough to blow quickly should there be a short in the feed wire. Highly unlikely with a plastic body, but better safe than sorry.
The charger you see in the pic will be permanently mounted in the battery compartment. It's a sealed marine charger for AGM batteries and intended to be permanently mounted. It's been sitting around and doing nothing for a year or so now, so might as well just leave it in the Argo.
There will be a mini ATO fuse box in the dash under an open-able panel that will provide switched ACC for various systems. I chose one with 10 circuits and built in blown fuse indicators.
That's it for today, tomorrow I'll work on the ground circuit and fabbing the dash.
One PITA I did notice today was there seems to be fluid on the power pack tray. Looked like it was red when I touched it. Only thing that could possibly be is that someone, at sometime, filled the transmission with transmission fluid instead of 80w90. I was pretty sure it was empty when I had it out, but it can't be anything else. The PITA is now I have to pull the transmission back out to check for leaks that I might have missed. That is not going to be fun. Fingers crossed it's just a seal or gasket and not a cracked case.....
