Here's the Rookie 2-stroke heat race. I didn't catch the start:
Marc glad your up and running again. You gave us a little scare there. Hope to see you at Busco with all you wit and humor! I brought you some Cheerwine but with all going on i didn't get to give it to you. I'll make up for it in Busco. See you later.
Lewis
Everyone is always dissing the 40 chain but I have never had a problem either with it. I break the shear bolts on sprocket tubes and hubs before the chain brakes. Never had a new 40 chain break, just old rusty ones from the machines when I get them after sitting 20yrs.
Which I would recommend not to use older ones as when the break, they wrap around sprockets and will crack the lower tub 1st gen attex's anyways
I cut a strip of plastic and lay it in the chain channels to help in case it does break and I dont know if it helps yet to protect but seems like it would.
If you got an older fixer upper machine. Its a good Idea to just replace them before you run it.
Here's my video.
Thanks to Don, Whipper, Bridget, Lewis, Robbie and Allie for sharing their clips with.
Nice video, guys!!!!
Wow! You nailed it, George- great video! (again)
