Looks great, but all your tires need to switch which side they are on, if you are to use the buffalo in water. The "V" should point to the rear for best speed in water. All of your tires were correct in your original first two pictures, except the front passenger tire had the "V" pointing to the front, while the rest of the tires had the "V" correctly pointing to the rear.
hi
Recommend have the tires set up for water . What this does is reduce your traction when steering on the hard ground . It is a skid steer machine after all .
At the end of the day try in water direction first and swap them around and compare for yourself .
tomo
Almost Done YAY
New Photos 11-15-2011
Awesome! Very AWESOME! keep up good work!
ive got a picture request, id like to see your alternator setup once you get it all hooked up!
Thanks luke!
-WagZ-
Awesome! IT attatches to the trans! So is that a modification that somoene/you made. or was it like that from the factory? i would have figured it was a Motor drive system, rather than trans, however, either way i guess it would work. Just mainly operates when your driving, rather than at idle.
