Homemade Conquest Hardtop Build Thread
Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 82
Thread: Homemade Conquest Hardtop Build Thread
    Oct 2008
    Thornton, CO
    646
    Quote Originally Posted by thorn View Post
    ... I love the top and my top is sealed/enclosed in aluminum ...
    Way back when I chatted with Ed about how the top was made. Only the first few has the roof built upside down and then they switched and put the roof sheet on top. Yours looks like one of the later roofs.
    By the way, if the guy in Grand Junction that welded those up is still in business he will re-weld broken welds for free. I don't know who he is, I got a hold of him through Ed. I had him fix mine once. I re-welded once and then the third time I did the roof reconfigure. Mine lives outside in my driveway.
    Quote Originally Posted by bluebruin View Post
    ... but, I know it will cost $1k or more, ...
    have some experience with Paul's? (Actually, they did a travel cover for my boat last year and it wasn't too bad for this area.)
    But I think the shop Ed used to use would do one for $650 or so.
    It will be interesting to see your hard top. I was thinking of building one myself someday out of 1/4 coosa or thermo-lite board. Strong, light, waterproof. I do like the soft top though as it makes it easy to run with everything open. It gets pretty warm in there sometimes.
    Nov 2014
    Conifer, CO
    124
    thanks! that's a very generous offer! but, I know it will cost $1k or more, and honestly I just don't have the budget. Also, I think a hardtop might standup to being outside better, as well as being trailered. I can get most the materials I need for my hardtop cheap through work, so I am going to give it a shot. I think it will cost be about $200-300.
    great info. thanks for sharing. no experience with Paul's but i know how much soft tops run, and I can't imagine a custom one costing any less. Coosa sounds like cools stuff. I am cutting this on my CNC router at work, so I have to go with plastic or wood. Everything is so expensive though. I can get exterior grade plywood through work for a decent price and then I will coat it with some type of oil based paint. I have considered foam core PVC as its less expensive that some plastics, but its a bit too flexible and doesn't take paint well, and you would still have to paint it since its not UV stable. thermo-lite board sounds cool too, bet that's not cheap.
    funny you should mention the welding, I just noticed yesterday that one of the angle supports on the hardtop is cracked at the weld. if you can dig up the guys contact info, I'd like to talk to him about getting it fixed next time I am out that way.
    I am building in an operable window in the front doors, and an operable tailgate glass, so hopefully I can ventilate if it gets too hot.
    Nov 2014
    Conifer, CO
    124
    I have most of the plans drawn up for the top. It will be 12mm (1/2") Baltic Birch (high number of ply's, very strong). Its relatively thick plywood, but most of the top is actually cut out since the windows and doors are so large. So, I don't think it will weigh all that much. Unfortunately, that means a lot of wasted plywood as you can see here in my drawing. But, by making it from continuous pieces of plywood, it should remain strong. This plywood is very strong. The 4x8 sheets use "exterior" glue, as opposed to the common 5x5 sheets that use interior rated glue.
    Next I will program it into partworks for our 5x8 shopbot cnc router. Hope it works out, you only get one shot before you waste a ton of nice plywood.
    Nov 2014
    Conifer, CO
    124
    this project is on hold until I can solve my power issues (ie no HP at 11,000ft). no sense in adding weight until I know I have sufficient power to use the argo.
  5. #15
    Nov 2014
    Conifer, CO
    124
    power issues solved. will start working on hardtop again. After using argo at our cabin a few times, we've realized a few things. It would be nice to design hardtop in easily removable panels so that we can ride open air on nice days. also, the crosswinds on highway 285 on our way to the cabin make a soft top of any type impossible. It will get shredded on the drive to and from. we want an enclosed cab so we can pack our bags etc and put them inside the argo for the trip to the cabin so we don't have to pack the jeep, then transfer everything to the argo once we get to the bottom of the road at the cabin. also, weight is a major factor. in deep powder at the cabin, the argo does noticeably better even with a few hundred pounds less in cargo. The hard top must be light to minimize impact on performance.
  6. #16
    Nov 2014
    Conifer, CO
    124
    ok my project is back from the dead. finally some time to work on it. I cut the parts on the CNC yesterday.
    1st order of business was to remove the back seat in the argo since it interferes with the hardtop. The aluminum top stops where the sides of the argo are no longer straight and start curving around the back... Since my hardtop will basically hug the aluminum frame, I decided to remove the seat back that was bolted to the back hand rail.
    Then, I had to remove the old softop mounting hardware and aluminum channel, as well as some eye hooks the previous owner installed for lashing gear to the roof.
    Next I test fit my panels. So far so good. Seems like its going to work out.
    I plan to prime the wood with Zinsser BIN and then paint with oil based paint. Maybe a coat of epoxy when all done.
  7. #17
    Nov 2014
    Conifer, CO
    124
    more of my wood parts cut waiting for assembly
  8. #18
    Aug 2008
    687
    This looks awesome love it.
    Maybe one day I will have the 8x8 of my dreams....hello convoluteded design...
    Keep up
    E great work.
    What you going to us3 for windows?
    MUSCATEER 6x6
    MUSCA TUR BOTA then eh?
    94 F350 4x4 7.3 IDI ZF 5sp
    Al "Camo pants"
  9. #19
    Texas
    2,168
    Very nice thread, trust me when I say, if I lived or had property at that latitude I would have a top, liquid cooled engine and heater, wipers, etc. Nice build. Keep up the good work.
  10. #20
    Aug 2008
    687
    Turbo Diesel all day long!
    MUSCATEER 6x6
    Al "Camo pants"
