I have to replace the two front chains on my 2015(?) Argo XTI. What is a good vendor for RC60 HD chain by the 100' roll? I figure I will need to replace other chains before 100 additional hours so I might as well stock up.
I found some heavy duty RC60 chain at Red Boar Chain https://redboarchain.com/collections...iant=253937005
It has a fairly high tensile strength and thicker side plates (.125 vs. .095) Looking forward to trying it on the shorter front chains first.
Staying on top of the maintenance is key to keeping your machine reliable and extending the longevity of it. My argo is an 07 Avenger and before I head out, I give it a quick once over to make sure nothing has changed since the last outing. After a 10 day hunting trip every fall, I clean it up and make sure anything that needs fixing is done, oils changed, if needed. That way any repairs don't add to be overwhelming and leave you with a POS in a few years time.
@lenderhand , when I replaced my chains, I used Napa's heavy duty ones and have had a lot better success than their regular grade ones I tried. Naturally, you get what you pay for and I went the cheaper route initially with their lighter chains.
