driver clutch help
Results 11 to 20 of 29
Thread: driver clutch help
    2,641
    you may need to remove the engine mount bolts and just slide the engine over alittle. j.b.
    https://www.youtube.com/playlist?lis...oMUK58ebCRmHM3
    Here is a video of what I have going on.
    That engine is turning about 12-1800 rpm, the clutch opens just shy of that, gradually. If you are confident and careful, manually twist the linkage where the cable attaches and see if more rpm happens and clutches begin to work properly. Watch loose clothing.
    If the clutches work properly attempt to reach 3600-400 rpm with adjustments, starting with taking any slack out of the cable.
  5. #15
    Buffalo, NY area
    2,968
    I think you definitely have something bound up in the drive clutch, and it's possible that the driven needs attention too. Pull the clutch off the engine and take the cover off to see what's up.
  6. #16
    Fairbanks AK
    1,457
    Was part of your video at full throttle? If so Jim is correct, the engine isn't making enough rpm to fully engage the clutches.
  7. #17
    Sep 2012
    Hanover,PA
    1,012
    If it has been sitting for some time your clutch may be Stuck ? I didn't see any movement at all ??
  8. #18
    Thanks for the info on needing higher rpm. I ran the rpm's up higher and both the driver and driven clutch seem to be working properly. Installed new belt and finally got the right tension. So for the time being, all is well. I really appreciate all the help. I just purchased some new tires, and was wondering which way the v tread should be pointing? I will never be in the water, just on land.
  9. #19
    Fairbanks AK
    1,457
    For traction only on dirt the v points to the rear on the ground. The other way is for grabbing water to swim.
  10. #20
    Sep 2012
    Hanover,PA
    1,012
    This is a Very Open subject !
    Originally The V is to point to the Back. This way the machine Grabs / CUPS to dirt/snow/mud and ride on top for flotation and traction. You Don't want to dig down as these machine have very low ground clearance and will High Center getting you stuck. You already have good traction as you have 6 tire pulling !
    Some may say other wise BUT Look at Any old add for these machine and see for your self !
