Originally Posted by
mudNmallards
I’ll throw my 2¢ in. Maybe it will give you some help. My experience with tracks pretty much begins and ends with tanks but I’ve thrown and broken a few tracks and had to adjust them and every year had to replace the whole thing, pads and links for SQT training like every other tanker.
I don’t know if the wall thickness exists on a plastic track (never looked that close at the few tracked AATV’s I’ve seen ) but if you are having hole wear then that’s effecting the mechanical strength of the track and creating a damaging environment for any new pin installed.
If it can be done with existing wall thickness you might consider installing a sintered bronze bushing the full length of the hole and epoxying it in. Those are pretty cheap and can be bought in about any length or can be bought in sticks and custom cut on a lathe or good bandsaw and fitted with a file.
On the pins I would recommend going with an ISO grade 8 plated rather than stainless. They would have equal corrosion resistance and are much stronger than SS.
The lubrication might help you too. When I was in the deserts of Iraq I saw many tracks fail due to that moon dust wearing the pins out. The maintenance guys switched from the normal #2 grease they used to a #.5 grease. ( 5th wheel grease) It was thick enough to stay in there and act like a seal keeping crud out.
