I was having a bit of trouble with the Ice Cleats on my Adair 14.5" Pro Series Tracks. I'm a little hard on my machines sometimes, loaded heavy, rough terrain, ect. Anyway, I managed to Bend/Fold a bunch of the Cleats, closing them up like "Clam Shells". This was no doubt from spinning out on rocks, roots, ect. I ended up having to pull them all off....... Really don't need them in the Summer time anyway.
Also had some trouble with the 18.5" Adair Tracks on my daughters machine. After a few trips, it was time to shorten the tracks, I cut the chains, and pulled a full Grouser section out.... Perfect. But then, shortly later, I noticed that her machine was pulling to the right..... kind of in a wierd way. It would run true, then it would feel like something nudged the machine to the side, then straight again, then nudge to the right.....???? I played with tire pressures, started checking chains/bearings, ect. Finally noticed that 2 of the Grouser Spacers were broken on the outside edge of the passenger side track
. Not really suprising though, we have to force this machine between trees on some trails around here. Anyway, as the broken Spacers rolled past the machines front tire, the track would "open" a bit along the outside edge, deflecting the track enough to make it influence the machine to turn to the right, slightly. Of course I didn't have any spares for that, so I bumped up the pressures in my right side tires to compensate a bit. Not looking forward to trying to change out those Spacers in the Tracks, so if anyone has had this problem, and has any Tips....???? I'm all ears
