from my plug i have wires 2 and 3 both running to terminals 51 on the rectifier. i have wires 4 and 5 both running to my ign. terminal on my ignition switch (of ign., batt., acc., and starter). i have my power wire running from battery to terminal 53 on the rectifier and then to my batt. terminal on my ignition switch, along with the jumper wire between terminals 53. when i turn the key on without cranking it over wire 5 (from terminal 51 on rectifier to ign. terminal on ignition switch) gets hott to the touch along with my power wire from the battery and i get smoke from behind the flywheel. wire 4 though doesn't get hot. it also smokes when i crank it over and i have no idea what i'm doing wrong. Please HELP!!!
