Mine also had the pins. I went to bolts too.
So the rust is really on there good.
I tried the pipe wrench method of hub removal and...........................
LOL HEAVY DUTY
Well I guess I need a new pipe wrench.
wow, I have never seen that happen. That sucks.
So I tried again to remove the hubs today
Snapped another Monkey wrench.
Then I made a slit in them and heated them up and soaked them with more PB BLaster
I only made the slit on one side. Wondering if I should put a slit on the opposite side of the hub?
I'd give it a bit of a beating. Put it on an anvil and flog it with a hammer while turning it around.
I finally gave up on the Scrambler hubs and took them to a machine shop to be pressed off. Cost? Priceless.
So you took the whole thing to a machine shop? Or Is there a way to get the axles out with the hub on?
Looks awsome, I amgetting one here shortly and was wondering on the actual size. Could you possibly get a picture with a full size man by it. Im 6' and about 275 pounds and am wondering how welll i'm going to fit.
**Also,those are piewrenhes. Monky Wrench's have a qooden hande and have a flat spot on the back ofthe jaws that can be used like a hammer. Im only saying this because I larned it like a few days ago in my Automotive Tech class.
