I was sad to hear the Rule is longer made & found a sight that still sells parts (Rule Winch Parts Supply & Repair - In Stock!) when I bought my 1999 Conquest it came with a Rule 4200 & when I went to use it for the first time, there was some sparking going on when I put the hook to the "D" ring, disassembled & found the brush holder broke, cleaned it all up & made an Alaska backyard repair till I could get new parts. Well 1 & 1/2 years later it is still working GREAT & just located this above metioned sight, contacted them & they have a new motor in stock with brake at $260.00 with a $140.00 core. Little spendy but this winch pulled an overloaded argo with trailer up hill after I spun out, my 50 foot cable was about 10 foot short, but with that spare rope that everyone wants to know why you are caring that all the time for, finally came in handy!
By the way RD, I bought 2 new clutches this past spring, after running them this summer & after moose hunting, I modified the driven (tranny clutch) like you suggested, using the # 1 hole for the spring & this made an unbelievable difference in the performance! Turns on a dime in high gear, engine brakes down hill like you would not believe, in low gear! Made a new machine out it! I'll wait till the drive clutch starts to show some signs of weekening or next spring before adding a shim. I added a shim to the old drive clutch spring after cleaning it up & adding dry graphite, put it on my brother inlaws machine & now he won't give it back! sniffle sniffle, we are gone rebuild his old for a spare & now I have 2 more machines my buddies want me to "TUNE UP" their clutches. Easy fix really, so just wanted to THANK YOU for your input & videos. Much appriciated!
..............................my 50 foot cable was about 10 foot short,............................(Posted by moose-a-boo)
Murhpys law of winching; If you have 50 feet of cable on your winch, you will get stuck 51 feet from a good anchor point. If you increase that cable to 100 feet, you will get stuck 101 feet from a good anchor point. Therefore, it is a good idea to carry the extra (I keep 50 ft with hooks on ends) cable. And I carry a cable pinch so I can hook anywhere along the length of the cable when rigging if I have to.
It's all just nuts and bolts.
