Hi guys! I still do lurk.
You need an engine management system- absent activating the injectors it is responsible for telling the coil when to make spark, and this also involves spark and therefor timing advance. I believe you could jerry rig something, but there is no way it will ever run at a satisfactory level. If you want to, you could adapt a "micro squirt" box and shoe horn in the wiring, but it may or may not work. I learned ALOT from the guys at
Geo Metro Forum.
What you need for a G-10 motor swap:
Running engine (try to find a car that runs with a blown trans. Once you start asking around, seems like there is one or two some place.)
Wiring harness
ECM
transmission from the car- so you can cut the bell housing to mount the starter.
Inline Fuel pump- if it s throttle body injection it will need 40 PSI- i forget the napa part number
Relay for starter (napa)
relay for fuel pump (napa)
Return fuel line if it is fuel injected
radiator, and radiator and radiator fan
clutch
clutch adaptor to the motor.
4 "pucks" snow mobile style for motor mounts
fabrication skills to mount the motor
The reason IMHO to plant a G-10 in an AATV is because it is a cost effective means to get a reliable fuel injected power plant that is four stroke. If you want something that is turn key ready to rock, look at any 340 or 440 fan cooled snow mobile engine (hopefully with electric start)- WITH the ecm and coils and clutch (you should be able to source a complete 1990-2000 sled for $500 and put a top end in it for 300). Just jet it for your temperature and altitude and have a blast... this elimantes the electric fuel pump and radiator and a TON of electric nonsense.
