Here are some pictures of our Mudd-Ox on a camping trip this week end. 6 adults and 3 kids we camped about 16 miles from the road. The gray looking sand is really glacial silt from the Knik glacier. Will post some video in the next couple of days.
All things Alaskan Mudd-Ox
16 miles of fairly flat terrain, it appears. You must have had plenty of time to cruise out at the upper speed range. How did they fair? Did you check the top end speed? (you may have them lower geared still). Also.....I'm sure the temps are fairly cool up there still, but did you have any heat issues after cruising for extended periods of time? How are the spring tension adjustments on the clutch working out?
The trailers look cool. I bet they came in handy for camping gear. Are you making the adjustment from tracks to tires pretty well? I hope peoples' teeth aren't being neglected with all this play time you have...........
Yes some of the terrain was fairly flat and we were running them fairly hard. Max speed was about 15 but we were heavily loaded. Black machine had 4 adults and 2 kids and a portable crib, case of water and lots of other stuff. the trailer full probably weighted about 800 lbs so I am guessing abut 1600 lbs total. We stopped about every 7-8 miles which probably helped with heat issues although we never had to stop because of overheating. We did see around 200 degrees but that is below the limit of 220. they due tend to run hotter when roading as opposed to working in the mud ,snow etc and even hilly terrain. the design of the hydraulics is such that not as much cool fluid circulates when max throttle sticks forward on flat ground, any time you are moving the sticks much more cooling takes place . The clutch changes actually work to effectively lower the gearing as it keeps the secondary from opening as much therefore effectively lowering. It has much more torque for the steep hills and deep mud etc which is what we have a lot of. As soon as I edit the video you will see what I mean. The trailer are essential for the amount of gear we need to haul and to transport moose, caribou etc after a hunt. the machine feels like a hot rod without the tracks, we have over forty hours on tracks on the black machine. Don't tell my patients that I am out playing, they think I am at conference or something professional!! I will try and get another video or two posted in the next couple of days. On the way out we climbed some hills with the machine fully loaded with the trailer and scared ourselves a few times but the machine climbed everything we thru at it and the maneuvering around trees etc was amazing with the hydrostatic steering.
Thanks
Mark
akexpress,
The benefits of owning a Mudd Ox
" On the way out we climbed some hills with the machine fully loaded with the trailer and scared ourselves a few times but the machine climbed everything we thru at it and the maneuvering around trees etc was amazing with the hydrostatic steering."
I,m glad the spring modification that you made to your clutch is working out for you.
Amazing
The Mudd Ox is fascinating to watch. It looked like your left front tire was either very low on pressure or flat. Your ability to counter rotate in that situation gave you an advantage that would have a Max or Argo in trouble in those extreme situations. Neat to watch. Hope I get a change to see an Ox in some extreme Mudd up close and personal.
Looks like fun! That is a gnarly hill. Was that a chain-slapping noise? I wondered if the Mudd Ox had chains or not.I ride a brown '96 Max 4 (skid plate, roll cage, 26" Rawhides, 20hp, custom winch and tow plates) with a 2K front winch and a 4K come-along for back up. I pack 20'tow-strap, 2 chains and 2 hooks,a jeep jack, and a big block of PT wood. Also an axe and chainsaw. And mechanic tools. I have a tote with a tarp and bungees. Spare parts. Two rifles.Hey, arent I supposed to be able to have three passengers?
Originally posted by AKTrail View PostLooks like fun! That is a gnarly hill. Was that a chain-slapping noise? I wondered if the Mudd Ox had chains or not.
Pretty impressive if you ask me!I ride a brown '96 Max 4 (skid plate, roll cage, 26" Rawhides, 20hp, custom winch and tow plates) with a 2K front winch and a 4K come-along for back up. I pack 20'tow-strap, 2 chains and 2 hooks,a jeep jack, and a big block of PT wood. Also an axe and chainsaw. And mechanic tools. I have a tote with a tarp and bungees. Spare parts. Two rifles.Hey, arent I supposed to be able to have three passengers?
