On sperry rand wedges, there is a large "O" ring seal , as well as 2 thick rubber gaskets... i replace the gaskets with old Army truck inner tube pieces,,,,,works very well too
Hey Mike,
Thanks again for the pics and that article....I followed it to the letter and have yet to have any water coming in, and this is after quite a bit of hard use.....
BTW, where do ya'll buy your new flanges?? Is Recreatives the best source for these?? The flanges I have now must be shoddy because I have two zerk fittings that just pulled free....
Almost any hardware store or bearing place should have them. for me , it's Worth W Smith hardware, in olean, nyThey even have the double studded rubber motor mounts for 3.99 each, any size too.....
I've been working on a friends MaxII this week. I pulled the tires to grease the bearings and like most machines, when I put the grease into the fitting, it went all of 1/4 inch and came out on the outside of the bearing. So I pulled all the outer flanges and used a needle fitting to suirt grease directly into the bearing and push out the old grease and water, turning the axle 1/4 turn then grease, 1/4 turn then grease. It only takes about 15 minutes per axle and I'm sure the bearings are well greased.
I'm also in the habit of pre-greasing the bearing with the needle fitting before installation. You'd be surprosed the lack of grease in a brand new bearing.
