yES I THINK I LUCKED OUT AS THE bEARINGS ARE tIGHT AS IS THE INNER BUSHINGS.
1029161635-00.jpg1029161400-00.jpgStarted a rough mock up on engine and fuel cell. Looks like it is going to work out nice but need to lower engine some. But I am looking at making a new engine mount that is adjustable so that should address that issue. I see I need to cut some weld on one sprocket to get the L,R axle out and pull the frame.
All in all happy with the StarCraft !
Any ideas or input is Very welcome. Also if ANYONE has a pic of a Factory Racer I would like to see them as I found the factory roll bar mounting holes when I flipped the upper body over.
Thank you don !
Pulled the front four axles and bearings and front frame section. Got my aluminum plate for my motor mount also. ready to take the upper body to the strippers and then start the fiberglass work at the shop.
1113161424-00.jpg1113161425-00.jpg1113161425-01.jpgWell I got the new engine plate and isolators mocked up and set the engine and tranny in to see how the set up will go in. Can you all tell me the best place to get a belt ? also what are my choices on length ?
Tidy install
ST400R ATTEX(Smiley)
500 Super Chief
lookin good!
trans mount.jpgtrans mount 2.jpgStarted on making anew trans mount and still working on the chain adjuster .
See the trans pivot's on the front mount an adjusts at the rear to keep the Main chain tight to the rear drive axle.
Well as most of you have found out you move one step forward and end up Three steps behind !
I Roughed in my tranny mounts and Cool adjusters and Really think it will hold up very well ! Then I mount the engine plate . It looks good to go !
Ok I lower the engine on it and Rough in my belt line up and my belt is WAY to small AND I can't slide the engine forward because it HITS MY TRANNY ADJUSTERS !!
So now I need a Longer Belt OR a Smaller engine. The Kohler 18 is MASSIVE !
At this point I am thinking of just selling it and looking into another engine .
So hear is my progress so far. NOTE: This is a Mock up NOT finish product.tm2.jpgtm3.jpgtm1.jpg
