Need leads for HDPE rollers with bearings
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 34
Thread: Need leads for HDPE rollers with bearings
  1. #21
    Northern VA
    2,766
    I think Micmac's running into the same problem I am, Lewis. On the rear chains of the Hustler there's not enough room between the frame rails and the bottom of the body to use even a thirteen tooth idler. The original rollers aren't that good and tend to crumble after a while.
  2. #22
    Don is right. Plus I don't have enough clearance between my mounts and linkage for the t-20 shifters on the drive chain as well.
  3. #23
    statesville, north carolina
    2,604
    here are my finished rollers. ended up only needing to go 0.004 bigger on the I.D. of the Roller than the O.D. of the bung to get them to roll nice and smooth. Shawn (my "work for beer" machinist) is working on getting a price per unit for those interested in a set. I had to pay for the stick of Delrin ($67 for 14 inches) and he did the work for me. we are also going to look at other materials for both price, and function reasons although i think the Delrin is going to work out really well.
  4. #24
    Those look very good Brian.
  5. #25
    Jul 2009
    Cleveland,Oh.
    1,589
    " I had to pay for the stick of Delrin ($67 for 14 inches) "
    Brian, not sure exactly what grade of Delrin was avail but here are a few popular choices around my shop. McMaster/Carr 8576k29 is 2" dia. @ $ 16.46/ft. and a glass filled resin grade 8719k17 2" dia. is avail @ $ 42.69/ft. I believe deliery on a credit card purch. is aprox. $ 5.00. Not a huge savings, but $ is $. Joe.
  6. #26
    Jul 2009
    Cleveland,Oh.
    1,589
    Also, for a little more info (confusion,decisions that need made) go to mcmaster.com and search for 8747kac it's some tech data. Joe
  7. #27
    Jul 2009
    Cleveland,Oh.
    1,589
    micmac go to mcmaster.com and search for cat. pg. # 3498 it is an overview of polyurethane type matl's. I know this stuff is much "softer" than Nylon/Teflon/Delrin. Not sure how it would fare in a chain tension roller application as opposed to say, Delrin. Joe.
  8. #28
    2,604
    Joe, I'm not sure the actual makeup of the stuff we used, but it is ultra high wear. we use it for skid stops on the race cars. you can drag it on the track for 500 miles and only see a sixteenth of wear. we went to this from a product called Jabrock because this stuff is also very low friction.
    it's probably overkill for my application, but it was in the rack!
  9. #29
    Thanks Joe I'll check it out. I was planning on HDPE as that's what the originals where made of. If there are better materials I'd be game to use them
    Mike
  10. #30
    Mar 2009
    BERKELEY SPRINGS WV.
    179
    just a thought that kinda looks like a skate board wheel. i wonder?
