Max II Project
Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 53 of 53
Thread: Max II Project
  1. #51
    Jan 2015
    Dallas, Texas
    178
    Was able to press one sprocket off an axle, not so lucky on the other, bent the sprocket over. Tried again and broke the weld holding the sprocket on the tube.
    Will cut it off to save what's left of the axle.
    Due to financials, I will probably end up just tig welding the axles back together, and ordering new sprockets and sprocket tubes.
    Meep Meep
  2. #52
    Sep 2012
    Hanover,PA
    1,012
    If you have a Tractor supply around you thy may have a sprocket you can weld on .
  3. #53
    Jan 2015
    Dallas, Texas
    178
    Tractor supply had the 22 tooth #50 sprockets I needed. Only issue is their ID is 2", and the sprocket tube OD is 1 5/8". Took it to a machine shop and am having them cut me 6" of 2"OD, 1 5/8 ID tubing. Will have it back Tuesday and in the machine Thursday.
    Fitted the axles back in. Definitely not a capable machine without power to the front wheels. Was doing a 4 wheel burn out trying to drive up a curb
    Meep Meep
