First 6x6 500 Super Chief
Page 8 of 10 FirstFirst ... 6 7 8 9 10 LastLast
Results 71 to 80 of 93
Thread: First 6x6 500 Super Chief
  1. #71
    Sep 2017
    Nebraska
    84
    I figured i might as well go for.broke.
    Kinda glad i did. Pulled the chains and noticed a ton of play on both tension sprockets.
    Anyone know who i send my Trans out to get rebuilt? Or is this something I can do. I have never been im to a t20 but I have rebuild many a hydros I.E. cub and JD....
  2. #72
    Sep 2017
    Nebraska
    84
    Ok so with New points , coils, condenser ect, would I be good to go? I have no problem going that route, I just want a trail fun driver no racer here just fun. I had just read that they run hot and the CDI fixes the shutdown issue??????????
  3. #73
    CDI maybe a bit more reliable but they can go bad too.
    for points setting up the timing and gap is the the hard part.
    timed mine with a 12v battery and light, along with the timing mark
    on the fan shroud.
  4. #74
    best to stay with the bigger bearings on the idler sprockets.
    the 4 chain attex's use a spacer over the threw bolt allowing
    to go to the heavier or next size up bearing.
    the stock max IV idlers just won't hold up, i got maybe 2 hours tops.
  5. #75
    Sep 2017
    Nebraska
    84
    Are there two different size tension sprockets? My right one is larger than my left one!
    And for the life of me I can not find a master link on the right rear chain????
  6. #76
    not sure off the top of my head how many teeth, (thinking 17) other sizes
    will work i guess but your chain length may very in result.
  7. #77
    Sep 2017
    Nebraska
    84
    Where do I find new Axle seals, bearings . And the Rubber Engine Mount Isolators?
    Also do the two strokes require a special fuel pump or will any small engine type work?
  8. #78
    Sep 2017
    Nebraska
    84
    Few pix of my temporary work space lol spent over 10k on a workshop and im back in my garage again.
    But just till i get her sanded down then everything will be moved.
    Everything is labled in baggies and in my little sewing box lol.
    The big stuff is labled in the plastic bin, and the chains in the tub soaking in Diesel.
    Still alot of work to do but removed all the staples from the tub, need to cut some 2x4 to go around it all to keep it straight.
    Hope to get the frame out this weekend then blast it and paint.
  9. #79
    Sep 2013
    Caldwell, Idaho
    1,175
    Making do just fine
    ST400R ATTEX(Smiley)
    500 Super Chief
  10. #80
    Sep 2017
    Nebraska
    84
    Ok quick question. Would this work to convert over to CDI ignition system?
    Vintage Chaparral G29B SS 292CC Snowmobile Engine | eBay
