I purchased a 1998 JD 6x4 with Kawasaki FD620D Liquid Cooled engine that will not start and only backfires through the carb when starting attempt.
I have completed the following:
1. Compression tests show 175/180
2. Flywheel rotated to TDC on each cylinder and valves adjusted to 0.010
2a. I made sure of TDC with a screwdriver in the spark hole.
3. All push rods and rockers checked and confirmed ok.
4. Valves and rockers operate as should with starter motor, cam gear must be ok.
5. Spraying starting fluid in carb or directly in intake only can achieve a backfire through carb / intake
6. Spark / Fire tested and successful at each plug. Verified against block and with spark plug tool.
7. Fuel verified and confirmed at carb. Electric Fuel Pump.
Next Steps I am planning:
1. I ordered new spark plugs (NGK BMR2A)
2. I ordered a new carb
3. I will clean out the spark arrestor and muffler.
4. Planning on pulling the flywheel and checking woodriff key.
I am honestly stumped on this. I have good air, fuel and spark. I have tried with choke, air filter removed, carb covered with hand, spray, etc. Also, the oil is overfull and thin but clean and correctly colored. Possible fuel in gas tank from starting attempt too many times without firing?
Any help would be appreciated.
