What Lubricant for Argo Chain
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: What Lubricant for Argo Chain
    What lubricant should be used for Argo chains? Argo recommends its own, but what's the brand name equivalent? Thank you.
    Northern BC
    2,990
    I use Milcot 220 on my chains, I believe it's a ESSO product. I get it in 5gal pails. It's common in industrial applications, and works very well. Most of the Argo owners that I know use it. I use a paintbrush to apply it, it will not sling off the chains, and it will not wash off either. With the paintbrush, it's easy to apply without contaminating the brakes. It has an ani-slinging agant in it that helps keep it on the chains.
    Later
    Feb 2011
    Alaska
    9
    I like the idea of applying the lube with a brush. Rock Doc, how about some more info on the milcot 220 - can't find it on the internet. This forum is a must read for new argo owners - thanks to all of you for making my adventure easier (and less work).
    Northern BC
    2,990
    Try this:
    http://www.imperialoil.com/Canada-En...DESMillcot.pdf
    I was wrong, it's an ESSO Product.
    I came across Royal Purple's Max-Chain: Royal Purple Chain Lubricant . Thoughts?
    Mar 2011
    Québec, Canada
    253
    Hi, do you use the millcot k 220 on all the chains or if you apply chain lubricant spray for the other chain. What do you think about those spray lub can?
    Thank you
    Jack
    Northern BC
    2,990
    Quote Originally Posted by brebett View Post
    Thank you
    Jack
    I use the Millcot 220 on all the chains, but I do carry a can of spray lube with me just in case I think I have to give it a shot for some reason.
    Feb 2011
    Alaska
    9
    Thanks for the info Rock Doc. Makes sense to me, just need to find the product or a similar one. Thanks again.
    Mar 2010
    innisfil,ontario
    1,431
    ive been using amsoil metal protector/chain lube.dries to a waxy like consistancy and wont fling.only trouble is that it takes 3/4 of a can to do all the chains.esso millcot sounds like a cheaper way to go.
    I use bar oil, but it makes a mess, flings all over the place, my tub looks like the damn BP spill. Switching to something that doesn't fling would be a definite improvement. I have used motorcycle chain lube too, but its pretty expensive.
