I was reading about ATF recently, was servicing my girlfriend's dodge neon's automatic. I'm old enough to remember when there was only type F and type A. There are 2 types of automatic trans fluid, those with friction modifiers and those without. Type F is without. If you put anything beides F in an F transmission, it'd shift sloppy.
I always assumed F would require less pressure to keep the bands holding in a T20, chatter aside. The GM limited slip additive was to prevent clutch chatter, and back in the '60s was made from whale oil.
