I had recently made a new engine mounting plate that would allow me to adjust the belts tension if needed. When building this. I had also rerouted my oil drain line.
Dotted red lines show where oil drain line was originally. It used to end just behind the trans and is a pain to get at. Now I'll be able to drain it through a hose and out through the tub's drain hole.
Im curious, in the picture that shows the dotted red lines that are where my oil drain line was originally. Is this stock/ standard on other Hustlers?
