Original Size Hustler 950 Wheels?
Results 1 to 6 of 6
Thread: Original Size Hustler 950 Wheels?
    Sep 2011
    Mobile Alabama
    22
    What are the original wheel sizes that came on the Hustler 950?
    Sep 2009
    Bryan, Texas
    748
    They are 8" wide and 8" in diameter, with a 5 on 4.5 bolt pattern. I have some used ones for sale if you need some.
    2010 Chevy Silverado 1500
    1974 Honda ATC 70
    1986 Honda ATC 250ES Big Red
    There is no Z in Diesel!!
    Stonewall is right on, and the tires they used were Goodyear Rawhides, 21x11x8.
    Sep 2009
    Bryan, Texas
    748
    If you want to go back with stock tires, since the Rawhide is discontinued, you can get Carlsile AT101's. They are the same exact size and tread pattern.
    1974 Honda ATC 70
    Sep 2011
    Mobile Alabama
    22
    Thanks guys...That's what I have...I want to go with a wider wheel so I can put a 25 vampire tire on it...I'm not sure what width wheel and height to go with?
    Sep 2009
    Bryan, Texas
    748
    I plan on putting the same tires on my 950. The size Vampire you should use is 25-13-9. If you don't want to go to any trouble, and just get a set of wheels that will bolt right on your stock Hustler hubs, you can get a set of Argo or Mudd-Ox 9" wheels. That is the expensive route, as those are going to be $50+ per rim. What I plan on doing is using some stock Honda Big Red 3 wheeler wheels (9x9) and converting my Hustler's hubs to 4 on 110mm bolt pattern.
    1974 Honda ATC 70
