Originally Posted by
rookcaca
Hi all,
I have a 2014 650HD 6x6 with 25X12-9 tires installed, as opposed to the standard 24X10-8 tires. I know that these tracks will fit, and that the standard template used to cut these tracks to length will not work, due to the non-standard tire size. My question pertains to clearance between the track and the lower body and if I would have enough clearance with the 25" tires installed? I know that the Avengers run these tracks with 25" tires, but I don't know if the lower body is shaped to accommodate this.
Thanks in advance.
