Looking for advice and opinions here as I am putting the Kohler Magnum M18 back in my old Argo.
I did purchase new exhaust gaskets (genuine Kohler ones) which are some type of metallic gasket. Do you use high temp sealant with this or, just the metal gaskets on their own? If you do use sealant as well, what brand/type have you had success with?
They should be a graphite over steel or MLS gasket, they don’t require a sealant...
The only sealant I’ve used on an exhaust system of any kind has been ultra copper and just a dab of it to hold a gasket to a block or to get a tricky exhaust doughnut to stay in place while putting a Y pipe back on... the standard red/blue/grey/black silicone can’t handle the heat in an exhaust system.
