Fixing those unfixable sidewalls
Results 1 to 8 of 8
Thread: Fixing those unfixable sidewalls
    Nov 2007
    Fort Scott KS
    27
    I wonder if any of you guys have the problems I have when it comes to fixing my tires. I figured I'd show you some of what I've done to make those tires run when the tire man says he can't do anything. Both of these methods rely on the use of some kind of tire sealant after the repair. Most brands work well, currently I'm using slime and I'm very pleased with it.
    For holes that are caused by a puncture of some sort and are to big for plugs to hold, I have used carriage bolts with washers with great success. Use a bolt about the size of the hole with a washer on either side of the sidewall. The washer on the outside should be the next size larger than the carriage bolt. That way it will go tight to the top of the bolt without getting hung up on the square part of the bolt located right beneath the head.On the inside I use a lock washer too. Tighten it up until the sidewall is sandwiched between the washers nice and tight. Don't use bolts that are too long, an inch to inch and a half is plenty. That saves you from having long bolts sticking inside your tire and causing problems. Remount the tire, put the sealant in it and inflate it to about 10 lbs. or so. It'll probably be leaking air. Thats OK, put it on the machine and run it like usual. Check it every so often and pretty soon you'l notice that the leak stopped. After the leak stops you can return to the normal tire pressure of 3-5 lbs. If the leak doesn't stop when doing this put more air in and maybe more sealant and run it some more. It will seal up.
    For cuts on the sidewall that are to long for a bolt you can use what I call a Frankenpatch. Get a junk tire with sidewalls that you can cut. Cut 2 pieces of sidewall about an inch and a half bigger than the cut is in the tire you're trying to fix. Get a bunch of quarter inch carriage bolts with nuts and washers, enough to go around the Frankenpatch every inch or so. Drill holes with a quarter inch bit into the outside patch, the sidewall and the inside patch every inch or so the whole way around the cut. Insert and semi tighten the bolts as you go. When you're done tighten them up all the way and remount the tire and add sealant as above. The sealant will again seal the tire up as its being run.
    It should be said right here neither of these methods should be used on any street tires, and I've never used them on 4 wheel ATV tires. Only the slow moving low pressure amphibious machines should attempt this. I'll put up some pictures of a tire that I own that has both types of this repair done to it. I use it as a spare now, but just the other day I had it on the Argo while I was repairing the regular tire. It ran fine and has for a long time. The Frankenpatch was put on because of a cut in the sidewall about 2 inches long caused by barbed wire getting wrapped around the axel and still being fastened to the fence. When it pulled tight the cut resulted.
    A couple of lst notes. I use carriage bolts because the rounded head catches on less stuff as you drive. Also if you have ever tried to break the bead of an Argo tire with hand tools you will find it to be almost impossible. Take it to a tire shop and they can do it in a minute. Many times they won't even charge you. Or if you are a true do it yourselfer, northern tool used to sell a little tire changer that cost about 40-50 bucks. It was well worth the money and very easy to use.
    If I can help anyone out, drop me a line. I'll do what I can. Phill
    pheagy,
    That is a unique solution. Thanks for posting that. I will copy it to the articles section.
    Nov 2007
    Fort Scott KS
    27
    Fixing those unfixable sidewalls (better pics)
    Sorry about the pictures with the first post. These are better and will show you what I'm talking about. Phill
    Tulsa, OK
    1,725
    Well, that's thinkin' outside the box.
    On a 4x4 site, a guy said he sewed up a long gash with weedeater cord and tubed it. So you're not alone in tire fabrication.
    Nov 2007
    Fort Scott KS
    27
    Just making 'em last!
    Roger
    I just try to wear out the darn things before throwing them away. Tubes are fine for some applications, but I find any where with cactus thorns to be not one of them. Every time you have a flat with a tube you have to do a complete break down. I like to stay tubeless if I can. Thanks for taking the time to read my post. Phill
    Sep 2007
    My House
    356
    I like that, quick solution to a big problem!
    I use a method that Ive carried over from wheeling the jeep. I have patched sidewalls with long cuts. I guess I should say rigged. I use a heavy sewing needle(heated up & bent), and 100lb fishing line. I prefer gorilla wire. It's stronger than what the line is rated at, and is smaller. I use a tire glue with a patch. Rough the torn area, place the patch on the outside of the tire, use multiple patches as needed. I use a silver sharpie marker to keep track of where the tear is, and sew the tear up like fabric. place another layer of glue on the outside of the sewn area, and cover with a strip of rescue tape!
    Rescue Tape Self-Fusing Silicone Tape ~ The Ultimate Multi-Purpose Repair Tape!
    I picked this up when watching a few pro rock crawlers repair a busted lower radiator hose! This tape could almost do the job all by itself!
    Jeff
    02 Argo Bigfoot
    Nov 2007
    Fort Scott KS
    27
    Good info
    I've never heard of the silicone tape. I'm gonna check into it and maybe keep a roll under the seat. Always looking for something that works! Thanks Greasemonkey. Phill
    Sep 2007
    My House
    356
    No problem. That tape is killer! The first time Isaw it work, I'm standing there thinking there's no way that tape is gonna stick to a radiator hose covered in slick wet coolant! I was amazed that it did!
    Jeff
    02 Argo Bigfoot
