What is our mat'l of choice for fabricating an exhaust system for say,a 23hp Kohler. Thanks
Joe.
Joe.
Joe, here is a post on what I used on Jennifer's Briggs' exhaust with some links to where I purchased pieces: http://www.6x6world.com/forums/max-a...html#post50025
Thanks Mike, thats the type of info I was looking for. Probably wouldn't hurt to be a little more specific when posing a question though. Also need to "hone" my skills of using the search function. Thanks again.
Joe.
So the tubing is basicly 1.25" O.D., 16 GA., 300 series stainless steel? Thanks.
Joe.
I used the 16 GA. mild steel. 1.25" O.D. from the engine into a 2 into 1 collector. Then 1.75" from there on out.
Ihttp://www.robertsonstorquetubes.com/
Joe here is one of the sources i used. They actually have a twin cylinder vangard pipe prefabed system for horizontal and vertical engines.
Kart Pipes - Briggs 10HP Go Kart Pipes
Here is a picture of their set up.
Hope this helps and they are very easy to work with.
Thanks Lewis, thats more of what I'm looking for. I like the short sections, would think it gives more options of routing.
Joe.
No, I bought the pieces pre-bent, and then cut them to get the routing I need and then tacked and welded them. I have a post somewhere telling what I did.
Here it is: http://www.6x6world.com/forums/max-a...html#post50025
