What needs replacing when the axel moves in and out about 1/4"?Bearings?
Could be the bearings. If you're lucky, it's the bearing collar. See if that came loose.
Also make sure that your bearing flanges are tight.
Look at the second page of the Max II Axle Replacement article. The first two pictures show you the nuts to check.
