2 or 3 speed aux transmission?
Results 1 to 10 of 18
Thread: 2 or 3 speed aux transmission?
    Aug 2008
    687
    I'm just curious if there is a small 2 or 3 speed transmission that one can mount the secondary CVT onto then an output to my Hagen or Rooters transmission???
    Looking for some uber low gearing with option of stock or slightly higher than stock gearing...just playing with options...in my head right now for when my diesel engine goes in
    MUSCATEER 6x6
    MUSCA TUR BOTA then eh?
    94 F350 4x4 7.3 IDI ZF 5sp
    Al "Camo pants"
    Look at either a Polaris atv transmission or an aftermarket Harley Davidson transmission.
    My father-in-laws Polaris Scramble tranny cracked and had to be replaced and I realized it is a stand alone transmission instead of being molded in with the engine like other motorcycles and atv's. It is only forward and reverse, no low range, but the other Polaris machines with high and low range might be stand alone transmissions like this one.
    Harley's have stand alone transmissions also, but you would want an aftermarket transmission to be able to afford it. 1st gear is 3 to 1 or 3.25 to 1 depending on the model. High gear can either be direct or maybe a .85 or so overdrive.
    Jun 2010
    Southeast Iowa
    256
    Seen this DIY gearbox floating around some time back... Looks pretty straight forward to build, and just what we all need... more chains and sprockets.
    Widdershins Way - DIY Gearbox
    Sep 2013
    Waldo Wi
    941
    Yep
    All the 90's Polaris 4X4s were Hi/Lo divorced transmissions, plenty of used ones out there for a few hundy.
    Jan 2008
    Vicksburg, Michigan
    3,508
    There was an enduro motorcycle in the 70's that had two rear sprockets. I think it was bultaco. But on road you put the chain on the smaller one. Off road you use the larger one. I only read and saw picture of it but I believe it only had one front sprocket. Kinda of cumbersome but works.
    Quote Originally Posted by Nubs View Post
    Yep
    I didn't know that, but if so, we may have just solved the 'low range' problem of the Max and other T20 machines. Another nice feature, at least to me, is that you could leave the T20 in forward gear all the time and use the auxiliary trans for reverse. No more having to pull the sticks backward to back up (that always annoyed me) If top gear gave you about 20 mph, low was 2 to 1, imagine how much power that machine would have geared down to 10 mph!
    Aug 2008
    687
    Quote Originally Posted by greg pinson View Post
    My thoughts exactly to have a fire road gear cause there is lots of that around here where I'm at and a uber low for when needed. I need just a forward geared unit no need for reverse, as my transmission functions much differently than the T20's most of you use. I've considered a T20 but I like what I have and it works well.
    MUSCATEER 6x6
    Al "Camo pants"
    Jan 2008
    Vicksburg, Michigan
    3,508
    There was someone way back that put a 3 speed trans/gearbox in a maxIV or it may have been a rim. Im going to try to find it again if I can.
    Jan 2008
    Vicksburg, Michigan
    3,508
    ok found it, lol. I was thinking Gus Marrone but wasnt possitive and it is. I havent found any details and cant find a shot of the setup.
    Aug 2008
    687
    Quote Originally Posted by LarryW View Post
    Thanks for looking at least, I've just been toying with the idea between a under/direct/over drive setup if at all possible..I just don't know LOL
    With the addition of the diesel engine, I'd like to think it would suite the setup well.
    Larry I also posted about belt length and percentage of gear change in this forum do you have any suggestions???
    Thanks again
    MUSCATEER 6x6
    Al "Camo pants"
