'94 Max II - Bearing / Flange replacement - Need a quick clarification
Welcome to 6x6 World.
Hi all,
Model: '94 Max II
Serial: 10608
I'm about to redo all of the bearings for the axles and would like confirmation I have selected the right items for purchase. The items are written how I envisioned they would fit onto the axle. Am i missing anything? That 15014 flange, can i use that on the inside of the tub as well? I see there is currently one on my Max.
62mm locking collar --- 15283 Outer 3 Hole Flange Greasable --- 15012 Bearing 62mm --- ???paper gasket (i see one available at max6x6)??? --- 15014 Outer 3 Hole Flange Non-Greaseable --- caulk strips---- (inside of tub) 15014 Outer 3 Hole Flange Non-Greaseable --- 15010 Axle End Bushing (Inner)
So if the above is correct, the shopping list would be as follows:
6 x 15283 Outer 3 Hole Flange Greasable
12 x 15014 Outer 3 Hole Flange Non-Greaseable
6 x 15012 Bearing 62mm with Locking Collar
6 x 15010 Axle End Bushing (Inner)
6 x 30075 GASKET, FLANGE PAPER OUTER BEARING - MAX II
6 x 1ft caulk strip
Thank you for any feedback, hoping to order today or tomorrow to have the parts for the long upcoming weekend!
While you're doing the bearings have you consider adding the inside bearings instead of bushings and split ring collars! It would be a very good up grade! With that setup, there is less of a chance of the axels coming out while you are 10 miles back in the bush! I lost the front left in that manner. Had to replace a lot of damaged stuff! I was only 25 yards from my driveway!
