Hey all, I've had a problem with the lower plug on the Trans on my max II. Shane Kearny gave me advice of bigger tool solves the problem, tried it, and it worked. Fluid smells burnt, not bad but obviously due for a change. Or atleast topped off. How do I remove the fluid in the case? I'm really hoping the answer isn't what I think it is of pullin the Trans and dumping it out. That seems like the only feesable way to me. I'm just thinking if I need to top it off with X amounts of Trans fluid and X amounts of slip additive, I wouldn't be able to get the correct ratio with having the Trans empty to start from scratch. Thank you for any advice!
