Avenger 750 Fuses
Results 1 to 6 of 6
Thread: Avenger 750 Fuses
    Jun 2011
    Northern, A.B
    61
    Avenger 750 Fuses
    Working on a 2007 750 Efi and the main fuse for the charging system is missing and i can not find any info on what amp fuse it should be. It's mounted in front of the engine, not part of the fuse block with the rest of the fuses.
    Thinking it should be at least a 20 amp, any info?
    Remove the firewall and check for an alternator, if you have one leave it go.
    Unless it's not charging, that is.
    Jun 2011
    Northern, A.B
    61
    No alt, i only need to know what amp fuse goes in the inline fuse holder.
    Stock system is working fine, but don't want to install to large of a fuse.
    Jun 2011
    Northern, A.B
    61
    Just a follow up, the charging system fuse is a 30 amp. No more issues with charging now.
    Aug 2009
    Pincher Creek, Alberta
    267
    Quote Originally Posted by jimsummit View Post
    What style of fuse is it? That might be a handy one to get a spare of...
    Totally forgot about this thread, the hdi's have a blade fuse and the non efi machines had barrels at the starter.
