Even if you fried the carb solenoid (if equipped) it would fire up with starting fluid. check both cylinders for spark when cranking. briggs ignition is a magneto and should spark every time the magnet on the flywheel passes the ignition coil IF the coil isn't grounded through the kill circuit. if you don't have spark, try removing the kill wire from the harness to the engine. this is a small black wire a few inches above the starter. unhook it and check for spark again. If it only has spark on 1 cylinder (the one toward the front of the machine) you have fried a diode in the kill circuit. this is a wire located under the flywheel shroud. it connects the kill terminal of the 2 coils and the diode keeps them form "talking to each other" unless the switch is turned to the kill position
