Is it possible to move pictures into a newly created "Album"? Thanks,
Joe.
Joe.
If you go to the main page of the photo you want to move and look at the top right of the photo where it says "photo options" i believe you can choose the "Move/Delete" option and then scroll down below the photo to choose the appropriate location to move it. Let me know if that works for you?
That's the first thing I tried Mike. I'm not seeing move or delete in the pull down from "photo options",delete is an option after you select "edit" but still don't see "move",
Joe.
Joe, If you go to the drop down Mike mentioned and click "edit photo", there is an option for "Change category? (leave blank to leave alone)".
click the drop down next to it. All of the sites default category's will be listed first, followed by all of your albums. highlight the album you want to move it to, and click on "submit changes" at the bottom Capture.jpg
Yep,that did the trick.I would have never found that on my own.Now I can organize my album(s) better. Thanks Brian!..............again!
Joe.
