attex 4chain
Results 1 to 10 of 18
Thread: attex 4chain
    Jan 2009
    laurys station Pa
    54
    attex 4chain
    i recently got a 4 chain attex i was wondering if it would hold up with a 540 yamaha snowmobile engine. it also had a T-20 trans in it at one time
    l___>
    000
    what good is it if it dont float
    Quote Originally Posted by 06chops View Post
    It should. I think I've read the T-20 can handle 80hp. I'd imagine that your engine would put out close to 50hp.
    Chains should be OK too.
    Jan 2009
    laurys station Pa
    54
    frame
    i know the T-20 will take the power of the motor i was wondering if the 4chain set up will take the power of the 540cc engine or will i be breaking chains all the time with that motor
    l___>
    000
    Sep 2008
    woodland pa
    537
    t-20
    somebody just recently posted they can handle 100hp found post by david berger --------------------------------------------------------------------------------
    IN THE 70'S ATTEX DID HAVE AT LEAST 1 100HP ALCOHOL POWERD RACER,
    AND WE KNOW MANY MACHINES ARE AS HEAVEY AS 1000 LBS WITHOUT EVEN THE DRIVER OR STANDERD AMOUNT OF BEER IN A COOLER ONBOARD,
    THEY CAN PULL 1000LBS OR MORE AS WELL, SO I THINK YOUR COVERD, NOW WHAT IS IT YOU PLAN TO BUILD THIS THINGY OUT OF?
    PLYWOOD??
    IF YOU CHOUSE TO LEAVE THE SCALE SLIGHTLY AND GO FOR THE UNMISTAKEABLE SIMALARITY END OF YOUR FULL SIZE MODLE YOU MIGHT BE ABLE TO MAKE USE OF AATV TRACKS AND STUFF LIKE THAT TO SAVE YOUR PROGECT FROM SINKING INTO YOUR BACK YARD AS A NEVER FINISHED DREAM,
    Buffalo, NY area
    2,968
    Hey Chops...
    If everything is aligned correctly (no bent sprockets, sprocket tubes, and chains running straight) you'd be very hard-pressed to break a #50 roller chain that's in good shape. Axle pins and sprocket tubes usually sheer well before a chain goes south. The T-20 isn't the limiting factor. Just make sure everything has been maintained correctly, and correct anything that looks iffy. Worn sprockets, loose chains, loose axle pins, bad bearings, etc. cause catastrophic failures more often than not. The key is to not shock load the system (that is, rev it up and dump the sticks.....). Stuff breaks real fast that way... :o)
    ~m
    ~m
    Now, if you want to do one heck of a wheelie, that's exactly how it's done.
    Bridget
    Jan 2008
    Vicksburg, Michigan
    3,508
    The 4 chain set up is probably just as strong as the 6 chain. It may be faster even ,with less moving weight. Its just the 6 chain setup is easier to adapt a motor into mounted low. The 4 chain setup is just a pain in the butt to adapt a motor not OEM into.
    Buffalo, NY area
    2,968
    Quote Originally Posted by Model Citizen View Post
    Bridget
    You're a horrible example to newcomers to the hobby, and a particularly bad influence on those with less experience, and who just want to learn.
    It's wonderful having you around!...
    ~m
    statesville, north carolina
    2,604
    ~m
    your also a horrible example to those of us who have been around long enough to know better. what can i say? wheelies are fun
    Jan 2008
    Vicksburg, Michigan
    3,508
    Im old enough to know better but still to young to care! Lets wheelie.
