Sperry Rand Tricub
Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 59
Thread: Sperry Rand Tricub
  1. #41
    Sep 2009
    Bryan, Texas
    748
    Here is a link to a differential axle that Northern Tool sells for go karts. It might be just what you need.
    Heavy Duty Differential Axle — 38in. Length | Axles + Components | Northern Tool + Equipment
    2010 Chevy Silverado 1500
    1974 Honda ATC 70
    1986 Honda ATC 250ES Big Red
    There is no Z in Diesel!!
  2. #42
    Jul 2009
    Lancaster Co, PA
    92
    Quote Originally Posted by stonewall View Post
    I know somebody else that was trying to retrofit that axle into a Tricub. The biggest issue is that the original axle is 7/8" and Northern axle is 1". He was going to try and find 1" bearings with same OD as the 7/8", so he could use the same flanges and not need surgery on the frame. I haven't spoken with him in a while, so I don't know if he was successful or not.
    SPD Tricart X5
    SPD Tricart
    SPD Tricub
    SPD Minicub
    SPD Wedge 295
  3. #43
    I was able to get over to our local small engine repair shop/junk yard. As soon as I showed a pic of the differential I was looking for they knew exactly. They said that Toro small riders used them a long time ago and that was a common axle assy used in homemade gokarts. Well needless to say they had a assy. with the tires. The assy had one short axle and one long. I needed another axle because my original one could not be used due to the previous repair. So I pressed off one of the diff gears from the short axle. Wow, that was really one there but came off with no damage and I will be able to press it back on to my other good axle. Now the other Toro long axle is about 1 1/2" shorter than the original Tri Cub axle. It still goes into the wheel hub a safe distance but I might have it lengthened just to make sure. I've been busy with other things but at this point I have and located all the pieces to completely get both of these Tri Cubs back together in working order. Now time to get parts washing!!
    Toro assy
    Pressed off gear from the Toro axle.
    Inside of the diff. Not very heavy duty feeling!
  4. #44
    Jul 2009
    Lancaster Co, PA
    92
    That's cool to have identified that diff. Do you know which Toro family of mowers that they came from? If those bevel gears are only pressed on, you should be able to make axles (or have made) any length you want from some basic 7/8" shaft mat'l.
    SPD Tricart X5
    SPD Tricart
    SPD Tricub
    SPD Minicub
    SPD Wedge 295
  5. #45
    I have not yet indentified what Toro(s) they came from. I looked around the lot hoping to find a complete unit just for that but they didn't have anything that old. As far as the axles I will be able to use what I have with no issues which is good. But your right, it would be easy to have some made.
  6. #46
    Looks like Toro used these starting maybe late '60's to mid to late '70's. I found Toro's part# 11-1800 for the Diff assy. Here's a Linkto a parts list of one model.
  7. #47
    My mom just found an original belt to the Tri-Cub, it is a Comet 203597. Also the original price sheet and parts info. Cool stuff.
  8. #48
    Jul 2009
    Lancaster Co, PA
    92
    Nice find, hyper.
    SPD Tricart X5
    SPD Tricart
    SPD Tricub
    SPD Minicub
    SPD Wedge 295
  9. #49
    Jul 2009
    Lancaster Co, PA
    92
    Tricub tires
    I finally decided on 18x10.50-8 rear tires as modern replacements for the original balloons. Regarding size and shape, these are near perfect match, but obviously the tread pattern is different.
    I made wheel adapters using custom laser cut discs and studs that I found at a Polaris dealer.
    I borrowed a set of Carlisle AT 21x11-8s and tried out. These look more like the originals but there was noticeable reduction of power with this larger diameter tire and the 5hp Briggs. These tires would probably be ok with 8hp Tricub.
    Now I can ride without having to air up every ½ hour.
    Also got the Tricub ski and Minicub frame back from powdercoat.
    SPD Tricart X5
    SPD Tricart
    SPD Tricub
    SPD Minicub
    SPD Wedge 295
  10. #50
    I have to same tricub as you do. my tires run with the point of the tread to the front like a farm tractor. I like the ski idea. it looks like an old snowmobile ski, is it? Know anybody with a seat for sale? Thanks, John
