just bought an 1983 8x8 argo.now what?lol
Page 2 of 12 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 119
Thread: just bought an 1983 8x8 argo.now what?lol
    Mar 2010
    innisfil,ontario
    1,430
    that machine probably has 20" goodyear runamucks under it. they are no longer made in that size. anything bigger and you won't be able to use your tracks. i believe that 22" is as big as you can go without tracks before they rub each other and the body
    yes sir,you are correct.the tires are 20x11 goodyear runamuck tires.i really wanted to be able to use the tracks in the winter,is there another alternative?
    thanks.
    Dec 2008
    New Brunswick Canada
    320
    Surely there is a 20" x 11" tire out there that you can find. Maybe someone knows right off hand and will advise you Buy the way, nice buggy
    Mar 2010
    innisfil,ontario
    1,430
    Quote Originally Posted by mike bar View Post
    i agree my friend,and worrying about tires at this point is like putting the carriage in front of the horse.haha.
    Oct 2009
    Ingersoll, Ontario
    88
    Nice Machine!!! Lot's of fun to work on them... I may have some plastic floor pans for ya if you need some. I am in Ontario as well. PM or email if your intrested.
    Have fun with the cleanup!!!!!
    Dezi Gebel
    2 Early 70's Argo's Will Merge To Make One!
  5. #15
    Mar 2008
    NL, Canada
    31
    Hi Racerone3;
    I had a 1984 argo 8x8 with a Kohler twin 17 that I used for work & play for 23 years. When I sold the machine it was on the third set of spark plugs. It was a very dependable motor. It had 2200 hrs on it when I sold it. I'm surprised that you used so many sparkplugs.
    Ride Safe
    EWS
  6. #16
    Mar 2010
    innisfil,ontario
    1,430
    member evil8x8 has the same machine, and i had one for a while. drain and replace the trany fluid before you run it... that kohler 17 will run great, but eats spark plugs like no 4 stroke i've ever met. if the chain tensioners are maxed out you will need to replace chain. the chains from the trany to the jackshaft are double 40, and the rest are double 50. the sprockets are pinned to the axles with roll pins. you will want to carry extras, along with a hammer and punch to drive them out and new ones in.
    good luck and keep us posted
    do the sprockets have to be attached to axle with roll pins?or can i guy use bolts?
    thanks
  7. #17
    Mar 2010
    innisfil,ontario
    1,430
    Quote Originally Posted by dezi View Post
    message sent dezi.thanks
  8. #18
    Nov 2009
    Tavistock Ontario
    40
    Weee Innisfil, I ride my bike through there quite a bit.
    '70's Argo 6x6 - Rebuilt from the ground up. Briggs 18HP Opposed Twin.
    Go where you want, don't get stuck, keep the rubber side down.
  9. #19
    Mar 2010
    innisfil,ontario
    1,430
    took a few more pictures guys.found the easy way to work on these suckers,split the shell.now i gotta get some chain,sprockets and bearings ordered.
  10. #20
    Mar 2008
    Rockwell, N.C.
    2,627
    I know we have used them on machine at Busco before. When those pins snap it will not pull good. You may want to consider a axle upgrade while you are at it. Splined axles and sprockets would bring that machine into the 90"s. I am not so familiar with you bearing configuration but before i bought old style material i would consider the newer upgraded axles. Just a thought. New up to date axles are not all that bad as far as price.
