just bought an 1983 8x8 argo.now what?lol
Page 3 of 12 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 119
Thread: just bought an 1983 8x8 argo.now what?lol
  1. #21
    Mar 2010
    innisfil,ontario
    1,430
    thanks lewis,this is the first argo i have ever had anything to do with.took the motor out and now have all the chains removed.next step is to start pulling axles.upgrade sounds good as long as it dont cost a fortune.
    thanks again.
  2. #22
    Mar 2008
    NL, Canada
    31
    Hi plott hound;
    I keyed the axles & sprockets on my 1984 argo, cost me $ 150.00 dollars for complete job. It was annoying having to unload everything in the back to replace the darn roll pins. I operated the machine with heavy loads in some tough conditions but never had an issue with the keyed axles. Best upgrade that I done on that machine. My new machine has splined axles & like Lewis said it might be worth checking out that option.
    Ride Safe
    EWS
  3. #23
    Jun 2009
    Fairbanks
    244
    So curious about this because I am way tired of replacing roll pins. Even knicked a chain with a hammer driving in a pin in the field last fall and boy did I have trouble then. The chain of course broke and I had to walk for miles, and then get pulled up a hill to get back home. If you did keys, why wouldn't I add grade 5 bolts and then just drive it a bit on the careful side? The axle upgrade is hard for me to figure out. Not sure where to start.
  4. #24
    Mar 2010
    innisfil,ontario
    1,430
    dont worry,will share all my picture when we get into this project.
  5. #25
    Mar 2010
    innisfil,ontario
    1,430
    here are another batch of pictures guys.i dont think ive ever tackled a project that i enjoyed as much as this one.
  6. #26
    Mar 2010
    innisfil,ontario
    1,430
    this week i took the frame and got it sand blasted.just finished painting it with chassis saver.theres nothing like a fresh clean start.
  7. #27
    Nov 2008
    Edmonton Alberta
    108
    Nice work! Think I might tempt doing that to mine next winter
  8. #28
    Nice and shiny! Looking good.
  9. #29
    The best thing I can recommend is to strip it down completely to the tub and power wash the hell out of it. The top body is pop riveted on if it's like my '85. If you haven't got a photographic memory take lots of digitals while your taking it apart. Mark the axles as to their placement and the sprockets to the axles cause the holes likely won't line up if you just throw it back together. You mentioned cracks in the body, get an old clothes iron that has the silk setting on it(extrememly hot) this beats the hell out of using a propane iron since you have no thermostate.
    For cracks, use the front edge of the iron to trough out the crack on both edges and then smooth the over flow back into the gouge.
    Give it a try and if your looking for more input I just spent approx. 200 hrs reworking a 85 8X8 so I may have a few suggestions to help out.
    As you can tell I responded before looking at all your pictures. The only thing I could recommend is to paint your frame a lighter colour as the black tends to make everything hard to see when its barried in the engine compartment.
    After 35 years of millwrighting we've finally got engineers convinced to do things so they're maintenance freindly.
    Good luck1
  10. #30
    Mar 2010
    innisfil,ontario
    1,430
    "As you can tell I responded before looking at all your pictures"
    no problemo my friend,been there done that lol.im at a bit of a stand still untill i decide whether or not to upgrade axles to splined type.guess i will tear the motor down and freshen it up a bit in the meantime.
    thanks for the tips! cheers.
