Stuck keys (removal tips?)
Results 1 to 6 of 6
Thread: Stuck keys (removal tips?)
    Apr 2009
    Brookfield, Wisconsin
    191
    I have some woodruff keys that are stuck pretty good in the keyways on some axles. In the past, I have worked them out with a wire cutter or the claw end of a hammer....but these seem to be stuck beyond my normal means. Someone out here has some helpful hints on getting them out....could I trouble you to share your tips?
    Have you hit them with large flat punch on either end? Might try some heat around them and soak with kroil ? or melt wax into them? Or you might weld a piece on top of them and pry out? Normally they fall out of terra tiger axles. Just pulled 6 axles tonight from a tt18 and all fell out )) It was well greased though!
    Peterborough, Ontario Canada
    93
    Quote Originally Posted by simpleton7016 View Post
    Woodruff keys or flat keys ? (Woodruff's are half mooned shaped).
    Woodruff Key:
    and Key stock:
    I would think soaking them over night in a mixture of sani flush and water will loosen them up. Yes Sani flush, available where any household cleaners are sold. It'll remove rust from anything.
    Apr 2009
    191
    They are woodruff. I got to out of the four to come out....now more surgery!!
    93
    Try the Sani Flush. You'll be amazed.
    Mar 2008
    West Allis, WI
    383
    I've always had luck with a hammer and chisel under the edge closest to the end of the shaft. You'll distort/ruin the key, but they are cheap and at most hardware or auto parts stores.
    It's all just nuts and bolts.
