Has anyone tried using 10" wheels on their machine. I am currently converting over from a balloon tires and was considering polaris or kawasaki rims. This would give me alot more tire options. What do you think?
You really might be in luck here. First off, if you use 10" rims, then you can get brand new 22x12.5x10 Super Swamper TSL ATV tires for only $18 each directly from Interco.
Cosmetic Blemished Tires Available Direct! | News Articles | Interco Tire
Your best bet would be to use some older Polaris 10" wheels because they had a 4x4" bolt pattern, not metric like Japanese 4 wheeler rims. This is a common bolt pattern so adapters to switch your 3 lug hubs to 4 lug would be cheap and easy to find.....you could also use this template to make your own:
http://www.6x6world.com/images/broch...ug-adapter.pdf
I was considering 24" bear claws, being a max they should clear the hull. I have a polaris rim but the offset is a bit to the out side. I am in the process of ressurecting an older max II . Ps just scored a 4 stroke clutch off an old swamp fox today
[QUOTE=jpswift1;66523]You really might be in luck here. First off, if you use 10" rims, then you can get brand new 22x12.5x10 Super Swamper TSL ATV tires for only $18 each directly from Interco.
Cosmetic Blemished Tires Available Direct! | News Articles | Interco Tire[QUOTE]
dang it JP... i wish you hadnt posted that... now i'm gonna have to try to cram a set under the wild wolf
try looking into real wheel.com they have a huge selection of custom wheels...you can get none beadlocks for almost any lug pattern
they even have them for a max and argo pattern...none beadlocks are about 90.00$ each..t-6 spun aluminum.
check it out
[QUOTE=racerone3;66536][QUOTE=jpswift1;66523]You really might be in luck here. First off, if you use 10" rims, then you can get brand new 22x12.5x10 Super Swamper TSL ATV tires for only $18 each directly from Interco.
Cosmetic Blemished Tires Available Direct! | News Articles | Interco TireHaha, glad to help. I hear the Super Swamper TSL ATV tires didn't really swim, but they are great in the mud. I think you should be able to squeeze those on the Wild Wolf. That would be a really aggressive looking Attex with those shoes on there!
Two of the balloons are in good condition. I put a polaris 10" wheel on my max. It seems like it will work best when put on backwards due to the offset,otherwise i am looking at getting 2-2.5" cut off of the axles to get the tires up under the max. I will try to get my adapters drilled for a 4 on 4" pattern today.Ps i already thought of putting another valve in the wheel.
