big problems here
Results 1 to 5 of 5
Thread: big problems here
    Oct 2009
    Rock Tavern,New York
    129
    big problems here
    max IV runnin' 25" rawhide III's. got a flat three days ago. found out that the valve stem had pulled out of the tube and only one bead on my rim had let go. put a new tube in and one half a day of riding ( always ride this machine easy) , and the second tube did the same thing. just put in my third tube at the local tire shop, and this time we marked the tire and rim. took it out for 15 min., looked at the tire and lo n behold the tire had slipped on the rim about 2". can someone tell me if i have a bad tire or maybe my rim is the problem. thanks again guys
    statesville, north carolina
    2,604
    these tires are meant to be run tubeless for that exact reason. will your tire not hold air if you put an automotive type valve stem in it? if that's the case, you need a new tire. a temp fix is to screw the tire to the rim and tube it. drill 8 equally spaced 3/16 holes in the outer lip of the wheel. then use short sheetmetal screws into the bead of the tire (about 1/2 inch screws... you don't want to go through into the tube). don't tighten the screws all the way down, leave just a little play between the screw head and wheel so that it has a little flex before it tries to rip the head of the screw off.
    Nov 2009
    Winnipeg, Manitoba, Canada
    36
    how did u cure yur problem as l have the same problem on only my right rear-the other 5 are fine-l run my machine careful, and l thought l was to hard on turning, but after 3 tubes($30. each) sheering off the metal stems l have to figure something else out. Hope u can help me---Thanks
    Like racerone3 previously mentioned to the original poster, you need to get a new tire or seal the one you currently have to the bead with permatex sealant and then use "Slime".
    Jun 2010
    Southeast Iowa
    256
    if your sold on running tubes in your tires then you might want to try baby powder in the tire. it used to work on the racecars. throw a bunch in before putting in a new tube, but like the others said running tubeless is better.
