Originally Posted by
wfo
ok my 2 cents....note you bought a pipe bender....you need a tubing bender...
a pipe bender is based on inside diameter and tubing is outside diam..so if your trying to bend
tubing on a pipe bender you will kink it..if you try bending pipe on a tubing bender you will
probaly break the tool..
upon more research, i found out exactly that. I have a tubing bender that i can borrow tomorrow and the cage will be done. i got this pos for 55 bucks... as I currently don't have a press in my shop, this thing will get modified into one. it should make a good axle straightener I tried using the shoe that actually fit the tubing, and also tried the sand trick with marginally better results, but for a cage that i want to look nice, and be functional I will be going with the proper type of bender
