chain care
Results 1 to 5 of 5
Thread: chain care
    Apr 2010
    Augusta, GA
    116
    chain care
    does anyone lube their chains, and if they lube them what do you use to lube them?
    Apr 2010
    Northwest Pa
    69
    I use cable and chain lube from napa. be sure to keep your chains clean such as no dirt or debris in the tube if you take yours swimming and water gets in dirt will too. I lube mine about every tank or so of gas i run through. The biggest thing is proper chain tension is maintained to ensure long life. for the chains there is no such thing as too much lube but it will cover the inside of the tub.
    If you will use the search here on the site, different lubes have been discussed quite a bit. That should give you some good ideas of the different products used and the results members have experienced.
    Apr 2010
    Augusta, GA
    116
    ok thank you guys
    o and also bierbower could you tell me what kind of chain lube you r using thanks
